Topic: what oil?
Whats the best oil to use in my 4agze?
Thumbs up Thumbs down
Re: what oil?
IM USING THE SHELL HX5 10/40.THE YELLOW CAN IN 20V
Re: what oil?
i toyota rally driver said that i must use bp visco 3000 20w/50 wich is a normal oil, ive been running that since. my 4age revs 9000rpm in every gymkhana and for 4 years that engine never missed a beat. hope this will help.
Re: what oil?
thanx guys.someone told me shell hx7.what grade are hx7?
Re: what oil?
4AGE motors were designed to use 20W-50
99' 20V RXI
126kw & 178nm - Economy Tuned (22/06/2010) Dynotech
http://www.photostand.co.za/images/f4orfh8edwxebuqyh5h.gif
Re: what oil?
since my fist 4age which is ST ive been using mineral oil 20w50 (Mobil) every 5,000 kms.
never had any problem with it.
www.grupotoyota.com.ph
BUMRACING
SBsalon
Re: what oil?
i think you have to chek the comp(if you can emission test),then see the miles on it,then how you treat your engine,if you race the engine and the weather.
then chek the manual for early and late model oil recomendation : sf or sf/cc certified
and then depending in the weather if it is extreme, you can choose your favorite one.
hop that helps
http://img704.imageshack.us/img704/7318/serchmarclogo.jpg
Re: what oil?
Hope I'm useing the right stuff.... Castrol High Milage (black bottle) - Got 270000Km...
Re: what oil?
Been using Motul Turbolight 4100 10W40 for a year then switched to Motul Synergie 6100 10W40.
No noticeable oil reduction during oil changes and the engine runs pretty smooth. Currently using Synergie and found that the oil temp dropped drastically... feels as if i've installed an engine oil cooler.
[[[TRD 4AGE 20V 0.8MM Metal Head Gasket for Sale]]]
Re: what oil?
Do you have the std twincam radiator on your ZE....and no oil cooler?
Run a thicker oil cos the ZE tends to run very hot...The best oil that I ever used in the ZE was Castrol Furtron but it is not available anymore....it was a 20W60 grade.
Never use fully synthetic without an oil cooler on the ZE...she will eat it up in no time....
Corolla RXi 20v                        Ex 88 RSi Supercharged
TRD 0.8mm Head Gasket           168mm Pulley @ 0.8 Bar
Yoshimura 270 cams                Aquamist Water/Meth
TODA valve Springs                  Full Cross Flow and Port
63mm Exhaust
PM me for all 9000RPM Stickers, T-shirts and Caps
                                   http://img.photobucket.com/albums/v187/twincamsam/10a4_3_resize_resize_resize.jpg
http://img.photobucket.com/albums/v187/twincamsam/3supras.jpg
Re: what oil?
do you have the manual to back that statement up  ../../extensions/custom_smilies_2/img1/sideways
