the 4afe, 4age i, ii, iii and 20v blocks have the same bolt pattern and will line up correctly
The diff between the 7afe and the 4afe heads are the intake ports being at a very steep angle as opposed to the 4afe and the 7afe has 1mm more lift. The exhaust side also has a small diffrence. The 7afe head will make a diffrence at higher rpm but remember to up the compression a little. you will also require a chip or piggyback to tune for optimum performance.
Regards,
SaintGP
If It Dos'nt Say Toyota It's Not Worth It
