Topic: Anyone know of someone who purchased 20v Tomei poncams?
Hi,
I would like to know if there is anyone who has bought a set and had it installed in a NA setup or anything cam with a duration 264 and lift of 9mm? I'm specifically looking for figures of this spec of cam with standard ecu. The reason I'm looking to purchase a set of Tomei Poncams and would like to see if it will be worth the money. I'm currently on 129kw with Std ecu, ported and polished Silvertop motor with Blacktop Throttles and cams and Trd gasket.
My concern is that the ecu had already compensated and won't do much more to get to my goal of 140kw even though I have purchased the Tomei's.
Feedback will be much appreciated.
Re: Anyone know of someone who purchased 20v Tomei poncams?
Hi
Hope this helps you.
http://www.importtuner.com/tech/impp_1207_tomei_powered_poncams/
96 Levin AE111 20v JDM
