Topic: throttle cable adjustment
There seems to be quiet a bit of play on my throttle cable by the intake, is it possible to tighten it?
http://i991.photobucket.com/albums/af32/160iSport/9ksig.png
Re: throttle cable adjustment
How does it feel when you press the loud pedal? What's your mileage?
The car seems to hesitate when the loud peddle is pressed, shes sitting on 280000km
adjust it such that there is no play but it must not be tight. or u will see your idle increase
Its not your top speed that counts but how quick u get to it...
05 - XRSi - 118WKW (Reef) - 15.7 @ Tarlton - 3.12.2010
01 - MR2 Turbo - 253KW ATF (Reef) - 14.4 @ Tarlton - 18.11.2011 - new time TBC
06 - Tuna 4x4
http://i30.photobucket.com/albums/c344/Diesel111/sig2_zpsm60s5g3e.jpg
how do you adjust it ../../extensions/custom_smilies_2/img1/ermm
follow the cable to the throttle body. you will see it goes around a bit at the end. there is a nut there which you can turn that will tighten it. sorry, thats about the best i can explain it...  ../../extensions/custom_smilies_2/img1/blush
06 - Tuna 4x4
there r  2  12" nuts at de end of de cable. have to loosing it ot nd ajust de nuts in. if dat aint helping ur cable is streched. make a new 1 up.
~ŁÍFŤÎÑĞ~AÏŃŤ~ĘÁŞÝ~
seems pretty straight forward, will give that a go ../../extensions/custom_smilies_2/img1/silly
