Re: MY 2.0 16V AKA 9AFE Build (7 Days)
8200rpm is impressive!!! Damn!
well i would say anything above 7600rpm is going to be fun. i'm not a drag person. i enjoy topend and torque. thats why i took it up to 2.0l you can not substitute displacment.
my camera got f????? and the other ones quality is so poor. but hopefully a get a buddys by tommorow.
Regards,
SaintGP
If It Dos'nt Say Toyota It's Not Worth It
http://i250.photobucket.com/albums/gg261/SaintGP/aa.jpg
Okay cant wait buddy.. So u say u gonna throw anchor at 7500rpm with urs?
@ TRD-TWEAKS no not going to anchor will test the limit but not hoping for a 9000 limit
got the camera working again so here goes
1> The conrods
left= orignal 7afe
right= H-Beam
http://i250.photobucket.com/albums/gg261/SaintGP/conrods.jpg
2> 83mm flat top pistons
http://i250.photobucket.com/albums/gg261/SaintGP/piston.jpg
3> Block Shaved for clearence on no.3 conrod
http://i250.photobucket.com/albums/gg261/SaintGP/blockshaved.jpg
4> Crank shaft with 3 dowels for flywheel
http://i250.photobucket.com/albums/gg261/SaintGP/dowels.jpg
5> Flywheel with 3 extra holes for dowels
http://i250.photobucket.com/albums/gg261/SaintGP/flywheel.jpg
6> intake manifold port matched, polished and cleaned
http://i250.photobucket.com/albums/gg261/SaintGP/intake2.jpg
http://i250.photobucket.com/albums/gg261/SaintGP/intake3.jpg
7> Cylinder Head port matched, polished and cleaned
http://i250.photobucket.com/albums/gg261/SaintGP/cylinderhead.jpg
8> Acl bearings
http://i250.photobucket.com/albums/gg261/SaintGP/aclbearings.jpg
9> Valves polished
http://i250.photobucket.com/albums/gg261/SaintGP/valves.jpg
10> My little helper
http://i250.photobucket.com/albums/gg261/SaintGP/myhelper.jpg
Regards,
SaintGP
Leka buddy... I sense power. Lol and torque... Lots of torque
well documented pics saint ../../extensions/custom_smilies_2/img1/wink
U gona definetly njoy the torque u get out of this motor...
180BHP 165NM
1400 vvt 13.9--> 400m 10/03/2012
Built by Ebrahim Shabudien
Tuned by Nazeem Sirkhotte
http://i97.photobucket.com/albums/l221/mureed/20motor.jpg
http://i97.photobucket.com/albums/l221/mureed/NissanChamp.gif
Got caught up today so no time for working on my motor. Blady Zooma's visit got me working up to 7pm. well we'll see tomorow
Regards,
SaintGP
Zuma spoiling da build even.. Damn arse
ya blady ass!!!
Regards,
SaintGP
Lol. U got any updates buddy?
I managed to clean up the block. This was a mission as i had ran bearings on the motor and the where lots of the fine bearing particles in the oil passages.
I used a spray gun with degreaser first and then petrol to clean the passages and plain old elbow grease for the top and bottom of the block.
Block cleaned and ready
http://i250.photobucket.com/albums/gg261/SaintGP/Picture002.jpg
http://i250.photobucket.com/albums/gg261/SaintGP/Picture003.jpg
Crankshaft cleaned with spray gun
http://i250.photobucket.com/albums/gg261/SaintGP/Picture006-1.jpg
Main bearings fitted to block
http://i250.photobucket.com/albums/gg261/SaintGP/Picture012.jpg
Main bearings fitted to caps
http://i250.photobucket.com/albums/gg261/SaintGP/Picture010.jpg
Thrust washers fited to cap TIP: use vasaline insted of grease as you will be able to see if there is any contaminants.
http://i250.photobucket.com/albums/gg261/SaintGP/Picture013.jpg
http://i250.photobucket.com/albums/gg261/SaintGP/Picture017-1.jpg
Crank fitted to block
http://i250.photobucket.com/albums/gg261/SaintGP/Picture025.jpg
I also did a oil pump mod. Check out the following link: http://forum.9000rpm.co.za/viewtopic.php?id=6763
This is where i call it a night. Will see again tomorrow. Cant wait to get it running.
Regards,
SaintGP
well done...
Im like very eager to hear when ur cab is done hey!!!!
180BHP 165NM
That makes two of us
Regards,
SaintGP
todays update (Can't belive it's taking me so long to put this thing together, But the fact that it will be worth the wait is what keeps me going.)
Cleaned pistons and rods with spray gun and assembled.
http://i250.photobucket.com/albums/gg261/SaintGP/Picture059.jpg
Then fitted Big ends and rings using lots of oil
http://i250.photobucket.com/albums/gg261/SaintGP/Picture061.jpg
Pistons fitted to block, note that the pistons at TDC are flush with the top of the block.
http://i250.photobucket.com/albums/gg261/SaintGP/Picture062.jpg
Doubled check the conrod clearance on cylinder 3
http://i250.photobucket.com/albums/gg261/SaintGP/Picture063.jpg
Will calculate stroke and C/R tomorrow
Regards,
SaintGP
oooh yummy!!!
Make sharp exse!! I wana hear it idling by saturday!!!
180BHP 165NM
trying my best. but keep getting disturbed. will try to put in some real elbow grease today
Regards,
SaintGP
put ur fone off & tell the wife that the only people allowed to see u would be those who will speed up the build!!!!!!!
180BHP 165NM
teamcam wrote:
u stroke the 7afe block to a 1998cc motor. U do this by purchasing a stroker kit...
This is a crank, conrods, pistons... could set u bad around 10k
I hear so much about this kit, some pics would be nice.
http://img.photobucket.com/albums/1003/SCHWARZERM/Avatars/90688RSI.jpg
Objects in the rear view mirror appear further away than they really are.
I can see those are Nissan Pistons but what rods are those?
You also running them pressed fit instead of bushed & floating?
Also to get to 1980cc with 83mm bore you would have to stroke an additional 5mm, that's on offset grind of 2.5mm!!
What is the big end size now & what bearings are you using?
mr 88 i honestly cant tel any info as im clueless.
Theres a guy by the name of Ebrahim down here in PE thats building & selling the kits off to customers.
I could pass u his details if ud like
180BHP 165NM
I need to redo my rolla & this is so tempting man.
Also those rods are not h beam, they are I beam - on H beam rods the flanges are deeper than the web - but those do look better than the 7a rods.
The rods are also nissan and they are running a full floating setup not pressfit. You're looking for pics... read the post form the start you won't be short of pics
update. found that the sump also needs to be shaved to clear no.4 cylinder. in TWO Places got this done just need to double check tonight
Regards,
SaintGP
Saint please provide us with a bit more info about the conrods and crank! Also I now those are CA18 pistons what i'm not 100% sure of is ,is it the DET or the normal DE pistons? Comp ratio wise what are u looking at?
Daily: 3rd Gen 3SGE sw20 MR2, 90 T-Top, Bone stock
Track Project:4AGZE,Sc14 charger 93 "Bubble shape" Corrola
Future project? TWINCHARGE
The Best of both worlds!
Boosted cars are like hot women. A little edgy, every guy wants one, some guys can't handle them, and if you throw a little alcohol in them they'll rock your world
http://i213.photobucket.com/albums/cc206/supercboy/Mr2/toyota-mr2-mk2--red-t-shirt1_zpsc80ccb3e.jpg
That is the DET pistons, n/a ones have raised section.
I was asking about the rods being floating or not because from the pics on pg 2 I see no small end bush - see I did read the whole thing so why the attitude I am merely asking a few Q's & making some observations.
