Re: Adjustable Fuel Pressure Regulator-*Updated with Results*
Any dyno results as yet?
Toyota Corolla RXi
63mm Tommys exhaust
2X50mm Primaforce downpipe
Exhaust cam retarded 1deg
140.2WHP @7800RPM-SPEED SHOP
27
So what benefit would this hav on a ST motor with management?
For all your digital requirements/supplies..pc (hardware/software),tv,carmeras,printers,ect..
contact 072 056 7379 or mail jrc20v@gmail.com  t&c apply
28
Sam?
Hey guys.....Im not sure about running it with management but from all the research i have done the optimal fuel pressure to run on a 20v is 3.0 bars. Std from is 2.7.
I say run the regulator and then tune with the mngt for best results.
Corolla RXi 20v Blacktop                    87 RSi 4AGE 16v "DBN Stock"- 282Wkw @ 1.8 bar
TRD 0.8mm Head Gasket                   Turbonetics 0.63 A/R T3/T4 turbocharger
Yoshimura 270 cams                         Turbonetics Evolution Wastegate
TODA valve Springs                          Built ZE 8.9 bottom end, ARP, FMIC
63mm Exhaust                                 Boost Cooler, Full Management
PM me for all 9000RPM Stickers, T-shirts,Caps
Legends Never Die....They are just Reborn with BooSt
                                   http://img.photobucket.com/albums/v187/twincamsam/10a4_3_resize_resize_resize.jpg
http://img.photobucket.com/albums/v187/twincamsam/3supras.jpg
30
Thanks buddy,any idea where I can get my hands on a adjustable vernier gear?
Well...im in CT now so we can find out who can make one?
When we having our first CT 9000rpm hookup?
Hi Sam
me from the Cape too so if wanna hook up or just need some help with finding places or looking for a smokkie aka yaard,shebeen:D don't be shy holla at a brother,I no how it is when u start off in a new City,otherwise I'm always willing to hook-up with Petrol heads.
here is my number
0833082240
Wayde
Ps
I still have all my front teeth;)
33
Hey sam..got someone to make me a gear..
Is it only the exhaust gear that is needed or both?
What will this gain on my ST with mangement?
How does 30/08/08 sound for CT hookup?
34
bump;)
hey twincam sam... any dyno results yet??
4AGE 20v blacktop- the true STREETFIGHTER!
I've a 20v blacktop with auto trans & I've added some stuff to improve the response at the lower revs; 1-3k rpm range because it's terribly sluggish until it hits 3k rpm. Since it's an auto trans, driving in town, that's the most used powerband.
1. Trust/Greddy E-Manage (blue) piggyback with additional Ignition & Injector harness & dyno tuned. It only gained 8 ps atw (from 112 ps to 120 ps atw) but then again, my intention is to improve the response on the lower revs, not Hp crazy. Afterall, it's an auto trans...:rolleyes: Hahaha.
http://greddy.com/img/PHP/products/jpg/524.jpg
2. MSD Blaster SS ignition coil, Ultra (brand) plug cables (used TRD & NGK before but the best is Ultra), Denso Iridium IK20 spark plugs & Pivot (brand) Raizin (model) volt stabilizer.
http://i182.photobucket.com/albums/x299/2Old2Rusty/DSC00244.jpg
3. Toda adjustable cam pulley (or you guys call them "vernier cam gears" ?) for the ex. I've not dyno tuned after installing this item yet as the dyno shop is about 3 hrs drive from my place; that's why I'm lazy to go.
http://i182.photobucket.com/albums/x299/2Old2Rusty/14112008006.jpg
4. I'm also using the 1JZ fuel pump.
After all these installed, I find that the response between 1-3k rpm have improved tremendously over the standard settings.
Now that you guys mentioned that the adjustable fuel regulator will help to further improve the lower rpm, I'm very excited about it & may probably go & install one.:)
I'm using this brand; SARD on my BEAMS and I think it's quite ok:
http://www.uniqueautosports.com/pricelists/Sard/sardregulator1.jpg
Is it difficult to get these Japanese stuff over in SA ?
Jip.
We cant get it over the counter.
Guys usuall all club in and then buy like 10 or more of a thing if it needs to be imported.
I bought my AFPR over Ebay tho
1986 Corolla GLi Twincam16 Sprinter
7AGE 16v (with spice)
132kw 200nm
14.6 - 400m Killarney S2S 01/08/2014(road tyres)
183km/h - 800m Saldanha 1/12/2012 (road tyres)
http://i92.photobucket.com/albums/l2/Ewird/12100019.jpg
ewird.muller@gmail.com
Two wrongs doesn't make a right... but three lefts does...
Ewie wrote:
Jip.
Oh, I see. There's another brand which is British made or something, called FSE. It's quite good too but I don't know if it's available in your plave though. We used it back those days when I was playing Ford Escorts.
The guys that are running aftermarket management,don't need the FPR,becasue when the car is dynod,they setup up the time that the injectors will stay open.This is only benificial if you running std management since we can't adjust anything on it.
20V RXI
293° 9.5mm Lift Estas Billet Cams,Toda Valve Springs
VDL Head Job,Dicktator Management
140kw & 181nm
05' 2.0i CiTi Golf
276 Estas Billet Cam
97kw & 175nm.
Thanks very much, bro.;)
Maybe it's time I save some money for a full management like the ones you mentioned...
Guys DO still use AFPR if using after market systems, it can still give u gains and benefits ur tuning potential allot. Management cant alter ur Fuel pressure! U can only adjust the duty cycles on the injectors.
Daily: 3rd Gen 3SGE sw20 MR2, 90 T-Top, Bone stock
Track Project:4AGZE,Sc14 charger 93 "Bubble shape" Corrola
Future project? TWINCHARGE
The Best of both worlds!
Boosted cars are like hot women. A little edgy, every guy wants one, some guys can't handle them, and if you throw a little alcohol in them they'll rock your world
http://i213.photobucket.com/albums/cc206/supercboy/Mr2/toyota-mr2-mk2--red-t-shirt1_zpsc80ccb3e.jpg
Thanks very much for the advise, bro.
In that case, probably I'll settle for a FPR first bcoz it's much cheaper compared to standalone managements.
Hi twincamsam
Is this with running standard injectors?
Hi Sam.That pressure you set the AFPR @ was on idle of course hey?
20V RXI
140kw & 181nm
05' 2.0i CiTi Golf
97kw & 175nm.
http://i167.photobucket.com/albums/u124/Herschel1_2007/Bump2.gif
for a reply
20V RXI
140kw & 181nm
05' 2.0i CiTi Golf
97kw & 175nm.
tenside wrote:
Hi twincamsam
Yes with the std 20v injectors
Fuel pressure regulator must be set on idle but with the vacuum hose disconnected which would give you the pressure under full throttle.....set it at 2.9 or max 3 bars here.
Fuel Pressure regulators also can be set up with full management. You can crank up the pressure to around 3.5 bar and then set up the fueling correctly on the management. This will give you better throttle response. Management cannot control the fuel pressure...it can only increase or decrease the fueling.
../../extensions/custom_smilies_2/img1/wink
Thats disconnected from the std FPR & connected to the AFPR?
Cause i installed it on my car & put it on 3bar,but i don't feel any difference,think it's cause of my C.I.A
20V RXI
140kw & 181nm
05' 2.0i CiTi Golf
97kw & 175nm.
i know my car over fuels a bit around the 7000RPM with the std FPR,so maybe i don't need it.
20V RXI
140kw & 181nm
05' 2.0i CiTi Golf
97kw & 175nm.
Sorry only read this part ofterwards.I was setting it with the cacum pipe connected. ../../extensions/custom_smilies_2/img1/sad
20V RXI
140kw & 181nm
05' 2.0i CiTi Golf
97kw & 175nm.
