Re: MR2 Spyder Quick Dyno Run
2zz-ge wrote:
on dynotech with CAi only!!!! some healthy torque there 193nm's
http://i13.photobucket.com/albums/a255/ … G_0001.jpg
Great graph, mine will be that smooth soon and the CAI makes good gains, I know that KSD reads lower than other dyno's, thank you for your contribution
Adding Bosson custom header (PPE replica, not to spec though) and 63-57 exhaust hoping to get that 200nm mark... header compliments of abrahamr ../../extensions/custom_smilies_2/img1/biggrin2
refer to link.. http://forum.9000rpm.net/viewtopic.php?id=2545
For 1800 thats fantastic, good to see other x's make good power.
Who needs management after gains like that
mr2zz-ge wrote:
The dyno graph show 183.9hp on engine and 152.6 hp on wheels?
KSD Runx posted the 155kw on his own dyno with his own car and lots of tuning, keeping in mind that his exhaust is less resrictive and has a longer CAI.
I'm planning to sort out my induction for the dyno, cause it suffers from heat soak when standing for a while.
Thanks for posting the graph very interesting and I can't wait to go back to the dyno once tuning is done.
With optimal tuning I believe that 155kw is achievable. Hondata makes a gasket that insulates the intake from the head's heat. One could ceramic coat the induction pipes and intake to reduce heatsoak.
One can try a bigger throttle body to increase flow to the intake, might be worth some power. Had been toying with the idea to reduce the plenum size of the intake to increase flow while adding some proper bellmouths, hopefully there will be some gain in that. Due to the split design of the stock intake, the modified plenum just bolts up.
Keep up the good work.
New intake is in the works, I have a custom intake from my 20v turbo which is 3" with 80mm throttle, will machine a adapter plate to make it fit. I believe just with tuning we will get 155kw, next stop 160kw and after some engine work and cams wow who knows.
Thanks for the support
big up on this project man, hope it goes from strength to strength.
in car sounds jus ../../extensions/custom_smilies_2/img1/biggrin2
is this car gonna be on track soon for a quarter mile time? S2S probably since MSA events are now 200 meters (low jack)
