Re: *** Project PLAYTOY...
Then second...
I cut and mounted the outer sections of the steering for the thickness and then did a lil bit of sanding to shape it... :smart:
And cut the center piece for the fingerprint scanner too... :thumbup:
http://www.civictype-r.co.za/phpBB3/download/file.php?id=2805&mode=view
http://www.civictype-r.co.za/phpBB3/download/file.php?id=2806&mode=view
http://s7.postimage.org/adzv37pxj/war_pink.jpghttp://s7.postimage.org/m9chx5jpj/WAR_copy.jpghttp://s7.postimage.org/fk5yh4ydj/war_red.jpghttp://s7.postimage.org/fyccduosn/war_blue.jpg
http://www.facebook.com/pages/WAR-Motorsport/389370507795772
Im so JDM my blood type is Type R
Then Naturally I had to test fit the Fingerprint scanner... :smart:
Testing the size of the mounting piece and it I need to build anything extra for the mounting of the steering to the hub...
http://www.civictype-r.co.za/phpBB3/download/file.php?id=2807&mode=view
http://www.civictype-r.co.za/phpBB3/download/file.php?id=2808&mode=view
http://www.civictype-r.co.za/phpBB3/download/file.php?id=2809&mode=view
Now before you guys ask...
The rings in the center of the steering is for the mounting screws that will be bolting the steering onto the hub. but need to make a small metal trim ring for both front and back so that it can be mounted nice and solid...
The "X"s that you see is where im thinking of mounting some switches... The top ones will be for the indicators (as I wont have any stalks) and the front ones will maybe be for hooter one side and the lights...
But this is just a mock up to see how it will all work...
Hey guys, small update...
Just been busy with the chassis brazing.
* Getting the spare wheel section closed off and welded up with supports
* Side chassis bars for the body roll
* Finalizing the shape of the doors and how I want it to look
* How Im going to open the doors (hinge placements)
* General clean-up and touch-ups of a few small things im not happy with...
